danny davis
Banned
Circuits that use RC for charging up a capacitor to cause a Delay in time
What value capacitors or resistors would it be to have a charging time of 1 second? , 5 seconds?, 10 seconds?
When using an RC network to do a charging time of 5 seconds but you get 20 seconds , what is wrong with the circuit? since the capacitors are old in the circuit can a capacitor that is in an RC network or a capacitor in an Op-amp intergrator circuit cause the charging time to get longer?
circuits at my work that are GOOD, work are 5 seconds in charging time for the lights to either turn off or on in 5 seconds after I push a button
I have to use a Stop watch to makes sure its 5 seconds the lights turn on or off after I push a button
If the capacitor is old , would it cause the time to get longer?
Because the bad boards at my work have different Turn on and off times that are not 5 seconds and they values on the RC networks are all the same values on the GOOD boards, What can be wrong with the RC timing?
BAD boards turn on and off the lights 30 seconds, 50 seconds , etc.
