raman00084
Full Member level 6
- Joined
- Nov 29, 2010
- Messages
- 375
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Activity points
- 4,076
i am having a pic controller that runs in 3.3v. i must generate a 5v pwm signal to control a rc servo, for that i am using a bc 547 transistor with a base resistor of 2.2k connected to pic io, emitter pin i grounded and collector pin i connected a 2.2k pull up with 5v.
now i connected the collector to rc servo pwm pin. is this the correct method, my doubt is the 2.2k pull up is OK will the servo move are it will need ton tum pole output?
