confi999
Junior Member level 3
Can I use this simple RC phase shifter for HF frequency band:
( 1) Is it possible to simply put such phase shifter between antenna, tuner and transceiver and get the proper phasing?
( 2 ) To make it work in different frequencies is difficult as Xc will change. How can I modify it to work in multi-band?
Any suggestion, reference will be highly appreciated. Thanks!
