cwrasmussen
I need to make a simple circuit that will go low after about 200ms to work as a delayed active-lo enable line (specifically for the 74ls540/541 chip). I tried the RC circuit in the embedded image, but I realized that won't exactly pull low because there is still a resistance to the ground. Sure enough, the signal goes to 2V (5v system). That signal goes to 6 541 chips. Should I take a second look to see if something else is causing the issue? Any other suggestions you guys have would be great!
P.S. I know I should know this stuff, so feel free to give me hell for my lack of education before I entered the workforce.
