thunderdantheman
Member level 4
When designing for thermal requirements, thermal data relates to the steady state final value. e.g. the junction temp of a MOSFET will eventually (theoretically) reach 305degC when dissipating 100 Watts with a 2degC/W heat-sink (Ta 25degC, Rth-jc 0.4degC/W and Rth-cs of 0.4degC/w). Clearly this Tj will kill the device...
I am designing a circuit that will dissipate power starting at a max of 200W and linearly decaying to 0W over 10 seconds. (Discharging a bank 20F 10V suppercaps). The duty cycle is extremely low.. at least 5 min in-between.. I want to get away with using the smallest heat-sink possible. How can I easily calculate the rate of temperature rise of the system.. that way I can map the max MOSFET Power dissipation (Pd) in accordance with the the thermal derating constant to achieve the fastest discharge for a given heat-sink capacity.
(e.g. A MOSFET with a Pd of 375W @ Tc 25degC mounted to a small heat-sink (6degC/W) could probably dissipate 200W for a couple seconds until the heat-sink capacity was such that the Tc gets to the point where the device is limited to Pd = 200W due to thermal derating.. How many seconds does it take? )
I understand that a 3D FEA software package would be desirable but sadly I don't have one Are there any other tricks to give me a ball park starting point to give me a better idea of where to start with a prototype?
