Raspberry Pi as a UDP or TCP server
bmandl
Full Member level 4
Full Member level 4
Slovenia
Ok, here is the idea. I want to use my Raspberry Pi as a server between PC application and microcontroller. Microcontroller unit will do some stuff and communicate with raspberry Pi via UART and Raspberry Pi will comunicate with PC application via TCP/IP or UDP protocol (Accesible over WWW). Also, I want my raspberry Pi to act as a interface between human and microcontroller (LCD and buttons will be connected on raspberry, so that microcontroller is not loaded with user interface and can do his job peacefully :) ).
My problem is, that I don't have basic idea how stuff works on Raspberry Pi. How can I run multiple programs on raspberry (working with LCD, buttons, TCP/IP, UART with mcu)? How does even programming look like on raspberry? I am used to programming on low level with mcu-s, but how can some device like pc (raspberry) works with low level stuff? And all low-level stuff must be mixed with high-level programming for TCP/IP communication and all that. Where can I start to get the basic idea how this stuff works?
PS.: I will probably write my PC application in QT, because I want it to be cross-platform but this doesn't really matters now.
Not really. This doesn't cover my questions.
I think I am getting the picture here. I can use wiringPi for low-level stuff (lcd on raspberry pi and UART with microcontroller) and then I can even use qt for high level programing like TCP/IP stuff. But can I run all these programs simultaniously like multitasking in background?
Respectively you don't yet understand how Linux operation system is related to the answer. Perhaps you should read about it though.
