alcatraz1972
I would like to try this:
I want to use 433 MHz transmitter and receiver electronics used for digital transmition upto 150 Kbps. At the transmitter circuit I would like to introduce a RF switch which could be modulated at 21 MHz (between antena and RF amplifier).
The idea is to send 12-bit at 150Kbps and afterward few pulse at 21Mhz. I know I need to modified my receiver or even design one because those receiver will filter the signal at 21 MHz.
My question is:
Is it posible to read-out the RF signal at 20 m if the original range was 100 m? or the signal will be so weak that is not posible to recover any more?
Please, could someone give any idea. I am new in this field and any feedback even if you think it is imposible to implement it
Thanks in advance
My question is:
Thanks in advance
