Random Time Delay in C
ninnymoggin
I want to put a delay in my code to wait for a random number of seconds before going forward. I'm new to C and coding in general so I tried to patch together two example functions I found (random and delay), but so far it's not working. This is what I have so far:
 // generate a random number between 1 and 5
int random()
    int i;
    for (i = 0; i < 1; i++) {
        int num = (rand() %
           (5 - 1 + 1)) + 1;
        return num;
//wait x number of seconds
void delay(int number_of_seconds)
    // Converting time into milli_seconds
    int milli_seconds = 1000 * number_of_seconds;
    // Storing start time
    clock_t start_time = clock();
    // looping till required time is not achieved
    while (clock() < start_time + milli_seconds);
main(void) {
    init_elecanisms();
    while (1) {
        if (start==0){
            int t = random();       //t=random number betwen 1 and 5
            delay(t);               //delay for random number of seconds
            led = ON;
            LED2 = (p1 == 0) ? ON : OFF;
            l1 = (SW3 == 0) ? ON : OFF;
what contoller compiler are you using?
1)your for() loop execute only once.
what is the rand() output range ?
in standard c it may be anything from 0 to 32k.
dividing by 5 , you may get a max of 6000 approx.
equivalent remainder of 2000(approx) seconds in your timedelay routine.
and you are conveting it into milliseconds and waiting for that time.
I'm using scons (is that a compiler, idk I'm a noooob).
I got rid of the for() loop in random() because I only want to generate one number, and set the range to 6 (I think) so it looks like this now:
int random()
    int num;
    num = rand() % 6;
    return num;
The code runs but there's no delay.
ok.scons is software construction tool -not a compiler.
which controller are you targetting and its compiler?
I don't know what you're asking me, could you try rephrasing it as if I were a five year old?
