random pulse generator verilog
jiang
Full Member level 1
Taiwan
verilog random
Hi guys,
In verilog we can get the random number by system task $random(seed).
If I don't give a seed, does verilog simulator use system time as the seed
or still simulation time as the seed?
If verilog simulator doesn't use system time as the seed, how do I use
system time as the seed or how do I guarantee to have a real random
numbers?
Best Regards,
Jiang
verilog $random
please see I2C APR protocol or Plug_&_Play speci
have LFSR + XOR for random number ..
$random verilog
I mean that I write the testbench which needs to do some random task,
not hardware.
LFSR + XOR is a pseudo-random number generator. It still has order.
random verilog
I think any random number generated by software will use timer to be its seed. Only hardware can pick up noise as its seed.
j2cheng
verilog random number
You can do it with PLI functions. If you search the forum you can find the PLI documents and explanations about writing C code for generating random numbers.
If you are desining an FPGA and using @ltera, you can use the its internal PLL's noise to generate random number inside FPGA.
random in verilog
Hi jiang,
In verilog, there is no such true random number, it is a pseudorandom number where the sequence is fixed. If you want to get different random number then you need to change the seed each time you perform simulation.
rgds,
SkyNet
verilog random seed
How about generate random number with LSFR?
