Random Noise of Charge Pump - Theoretically
gviva_2k
Newbie level 1
Newbie level 1
Santa Clara
Hello All,
Does anyone know how the calculate the Random noise generated by a charge pump theoretically?
We all know that, wider the up and down pulses in the locked state of a PLL (To avoid deadzone), more the charge pump noise integrated onto the loop filter. However, how do we arrive at a theoretical expression for this noise?
To put it in other words, what is the theoretical value of noise in a charge pump that creates random jitter in a PLL, if all the other components are ideal. (Say VerilogA models)
Take Icp (noise) of pmos and nmos, rms them together
I*Z gives you the voltage noise. You can convert to input phase noise etc.
Better to go to designer-guides.org and read about it.
Hello.. Thanks for the response.. I shall also take a look at designers-guide
