ramp generator question
anotherbrick
Full Member level 4
Full Member level 4
Istanbul , Turkey
hello dear forum,
I want to design a ramp generator
here is my circuit and the simulation result
my question ;
how can I seperately adjust rise and fall times ?
thank you
I'd use a simple "integrator circuit"
... at least I don't see a benefit in your circuit.
Klaus
hello thank you,
I dont want Vout exeeds Vin
Vout must be equal to Vin at the end of ramp
is it posible with integrator circuit ?
No, not with the simple integrator circuit.
Klaus
Try with individual resistors in series with the diodes.
Klaus
The simplest ramp generator I've seen / done, is a timing
cap and a pair of current sources, one fixed and one
switched. For a "sawtooth" the switched source is much
higher value and for a triangle wave it would be 2X the
fixed value (so sum, +fixed and -fixed).
Now you would also want endpoint control meaning a
pair of comparators for top and bottom phase termination.
I think about 20 transistors all told, in a DC-DC chip design.
If you aren't dead-set on absolute linearity then a switched-R
scheme could be simpler (and I prefer it for PVT with a pair
of supply-ratiometric thresholds). You could also use supply-tracking
current sources to get V rejection -and- linearity.
Maybe useful if you haven't seen it, RAMP GENERATORS
The linear ramp (sawtooth) I know works, not sure about Vout = Vin at end of ramp with it 'though, is the current source into a cap, with oscillator transistor draining cap.
Apologies for the circuit being backwards to standard layout, in a rush right now... The input to BJT base is any old squarewave. I seem to remember you can make it more triangle wave-like changing (R)C values. Again, doubt it can go to Vin, not sure.
