Ramp generator in orcad
Sadegh.j
Advanced Member level 3
Hey
How do we make a ramp generator in Orcad?
you have to place a pulse generator and adjust rise time,
Added after 52 seconds:
on time, fall time and off time.
regards
The problem is a synch voltage should be given to the circuit and the ramp generation should be synchronized with it.
or implement an integrator with an opamp and use a transistor to discharge the capacitor of the integrator, and there you have your ramp generator with synch input.
use 555 as ramp generator, see datasheet NE 555
