Radiation Pattern using ADS or Momentum
CarlosFH
Junior Member level 1
Could I get the radiation pattern of an antenna with lumped elements using ADS? When I use momentum I can not include lumped elements to get the radiation pattern and if I use ADS I can include lumped elements but I can not get the the radiation pattern. Is it possible to do that? Thank you very much for your answers.
Though I have not simulated radiation pattern in ADS, I think you have to generate the layout from schematic window for your lumped elements and then simulate them in Momentum.
