Radiation Intensity of Antenna
kakar133
Member level 2
Member level 2
USA
Hello,every one
I am trying to plot radiation intensity of antenna using the following code but it is giving me an error. please, help me
PI = 4.0*atan(1.0);
E = 120.0*PI;
L=1;
Io = 1;
r=2;
k=2*pi;
THETA=0:1:359;
polar(THETA,(((cos(k/2*L*cos(THETA*pi/180))-cos(k/2*L))/sin(THETA*pi/180))^2*(E*Io^2/(8.0*PI^2))),'--r');
and the error is given below
Error using polar (line 61)
THETA and RHO must be the same size.
Error in Q1 (line 19)
i resolved the problem but i am not getting polar plots in degree co-orditanates. can any body please help me . I have attached the graph and here is my code.
PI = 4.0*atan(1.0);
E = 120.0*PI;
L=1/4;
A = L*PI;
Io = 1;
r=2;
k=2*pi;
THETA=0:0.01:2*pi;
U =((cos(k/2*L.*cos(THETA))-cos(k/2*L))./sin(THETA)).^2*(E./(8.0*PI^2));
polar(THETA,U);
Append these lines to your code.
[X,Y] = pol2cart(THETA,U);
plot(X,Y)
axis([-0.5 0.5 -0.5 0.5])
plot(X,Y)
still i am not getting correct result. i wanna graphs with axis shown in figure below.
Then ignore my previous post
Normalize your U and then polar plot in dB i.e., plot 10*log10(U)
thanks for prompt reply...
what do you mean by normalize ?
I have added a few lines of code in the MATLAB program to rotate the 2D curve into a 3D object.
The entire code is below. I have adjusted the number of points in THETA and the repmat to be the same.
PI = 4.0*atan(1.0);
E = 120.0*PI;
L=1/4;
A = L*PI;
Io = 1;
r=2;
k=2*pi;
THETA=0:0.1:2*pi;
U = U/max(U);
xr = X.'*cos(THETA);
zr = X.'*sin(THETA);
yr = repmat(Y.',1,63);
surf(xr,zr,yr)
axis equal
but at L=1.25 it should produce graph like the one I mentioned in attachement.
PI = 4.0*atan(1.0);
E = 120.0*PI;
L=1/4;
A = L*PI;
Io = 1;
r=2;
k=2*pi;
THETA=0:0.1:2*pi;
U = U/max(U);
surf(xr,zr,yr)
axis equal
The graph you show (from the Balanis book) is in dB scale. Your equations are all in a linear scale.
The code I gave generates the correct shape of the lobe in the linear scale (based on your original equations).
If you want your result to look like the picture you posted, you have to convert to dB. It is not that straight forward in a polar plot, due to the nulls (log(x) approaches infinity as x approaches 0).
See [ **broken link removed** ]. I think that this file: [ https://www.mathworks.com/matlabcen...ot-tool-in-db-linear-scale/content/polar_dB.m ] might perform a good conversion to dB scale, which you then plot.
