T
treez
This 7A Ferrite bead, (its through hole, radial) has gone obsolete…..we need to find a like-for-like replacement
Murata BL02RN2R1M2B ferrite bead
https://www.murata.com/en-us/products/productdata/8796738420766/ENFG0004.pdf
Its used on multiple SMPS’s in a company’s stable of products. Sometimes its used as a series L for an output filter for offline Flyback or forward converters. Also, sometimes its being used in series with the FET drain in various offline DCM flybacks or forward converters.
The maximum current it sees in any product is 5A RMS.
We need to find a replacement, but there is nothing available anywhere. Does anybody sell the bare, Bent wires, that we could insert a cylinder ferrite over to make one ourselves?
The following Ferrite bead, B-01-R, by Kemet, is only rated for 5A, which is odd because its made of a piece of 0.65mm wire, just the same as the BL02RN2R1M2B, which says its rated to 7A, even though its wire is longer than the B-01-R.
Also, its difficult to compare these beads because the Kemet one gives its impedance as 2 Ohms, whereas the BL02RN2R1M2B gives its impedance as 1.1uH at 1MHz.
Kemet B-01-R ferrite bead
file:///I:/Temp/AM/OBSELECENCE/BL02RN2R1M2B%20_ferrite%20bead/KEM_LF0070_BEAD-L.pdf
We want to find a replacement which has less inductance, because it is used in the switching node of various SMPS's (eg in series with the flyback FET drain). ..But not that much less inductance, because then it won't have as good filtering effect in other products where its used as part of an SMPS output LC filter.
