rmmstn
Newbie level 6
Currently, I am working on a radar project which is given me and it can be found from mit opensource.(I am also attaching the schematic here). However, when I build this circuit, Im having a trouble with video amplifier stage. First of all, when I give +12volt from the ic's 4th node, my ic is getting very very hot so I disconnect it not to be burned. I checked its datasheet, it is showing for -+5.25v voltage range, too. I couldnt get how it is seen convenient to give +12v. What am I missing? Whenever I pass about 5.5v, the chip gets warmer. Also, how can I design an alternative? I need to know Rin and Rout for video amplifier right?. How can I find it out? (Input is coming to this circuit from a microwave circuit with -28dBm power)
If you can help, you may kind of save a life.
Thank you
Thank you
