scdoro
Member level 5
I am doing a frequency counter circuit wif PIC and need to input a signal to the RA4 of my PIC 16F872.
I have set RA4/TOCK1 as my external clock input for timer0
1) As stated in the data sheet, it say RA4/TOCK1 has a ST schmitt trigger input , may i know what does that time ??
2) Must the signal be pumped in be ST or TTL ?? ( meaning 0 to 5 V , no negative voltage or ? ??? )
3) If the input muz be a ttl, and my funtion generator don't have that function, what shld i do ?
4) If is ST input, what shld i do to input my signal ( -5 to 5 V) to the pin. direct connection can ? ? Is there anything i need to take note ?
Thanks a lot
Thanks a lot
