qusetion on asynchronous FIFO
hover
Junior Member level 2
China
Hi, everyone
Recently I have written code for asynchronous FIFO.
Below is my code:
module asyn_FIFO(Data_out,FIFO_full,FIFO_empty,Data_in,write_clk,read_clk,write_to_FIFO,read_from_FIFO,reset);
parameter                 FIFO_width=8;
parameter                 FIFO_height=8;
parameter                 FIFO_ptr_width=3;
output[FIFO_width-1:0]    Data_out;
output                    FIFO_full;
output                    FIFO_empty;
input [FIFO_width-1:0]    Data_in;
input                     write_clk;
input                     read_clk;
input                     write_to_FIFO;
input                     read_from_FIFO;
input                     reset;
reg[FIFO_ptr_width-1:0]   write_addr,read_addr;
reg[FIFO_width-1:0]       Data_out;
reg[FIFO_width-1:0]       FIFO[FIFO_height-1:0];
wire                      read_synch;
wire                      write_synch;
wire[FIFO_width-1:0]      Data_middle;
integer                   i;
assign FIFO_full=((write_addr==read_addr)&&(write_to_FIFO==1));
assign FIFO_empty=((write_addr==read_addr)&&(read_from_FIFO==1));
always@(posedge write_clk or posedge reset)
  if(reset) begin
    write_addr<=3'b000;
	for(i=0;i<=FIFO_height-1;i=i+1)
	   FIFO[i]<=8'b0000_0000;
  end
  else if((write_synch)&&(!FIFO_full)) begin
        FIFO[write_addr]<=Data_middle;
	    write_addr<=write_addr+1;
  end
always@(posedge read_clk or posedge reset)
  if(reset) begin
    read_addr<=3'b000;
	Data_out<=8'b0000_0000;
  end
  else begin
    if((read_synch)&&(!FIFO_empty)) begin
	  Data_out<=FIFO[read_addr];
	  read_addr<=read_addr+1;
    end
  end
synchronizer_write s1(Data_middle,write_synch,write_clk,write_to_FIFO,reset,Data_in);
synchronizer_read  s2(read_synch,read_from_FIFO,read_clk,reset);
endmodule
module synchronizer_write(Data_out,write_synch,clk,Data_valid,reset,Data_in);
parameter              Data_width=8;
output[Data_width-1:0] Data_out;
output                 write_synch;
input                  clk;
input                  reset;
input                  Data_valid;
input[Data_width-1:0]  Data_in;
reg                    Data_valid_synch;
reg                    write_synch;
reg[Data_width-1:0]    Data_out;
always@(posedge clk or posedge reset )
  if(reset) begin
	Data_valid_synch<=0;
	write_synch<=0;
  end
  else begin
    Data_valid_synch<=Data_valid;
	write_synch<=Data_valid_synch;
  end
always@(posedge clk or posedge reset)
  if(reset)
  else begin
    if(write_synch)
	  Data_out<=Data_in;
  end
endmodule
module synchronizer_read(read_synch,read_from_FIFO,clk,reset);
  output read_synch;
  input  clk;
  input  reset;
  reg    meta_synch,read_synch;
    if(reset) begin
	  meta_synch<=0;
      read_synch<=0;
	end
    else begin
	  meta_synch<=read_from_FIFO;
	  read_synch<=meta_synch;
	end
endmodule
My question is that can I use count to indicate the empty and full statuses of FIFO instead of my above approach. That is to add"count<=count+1" under code "write_addr<=write_addr+1" and "count<=count-1" under code"read_addr<=read_addr-1". But I'm afraid that count must across different domains. It will cause problem.
I am afraid that you cann't add"count<=count+1" under code "write_addr<=write_addr+1" and "count<=count-1" under code"read_addr<=read_addr-1". If you do so, race condition will arise and result in error.
The common way to implement a asynchorous FIFO is to use Gray code for the write address and read address. Then you can compare the two addresses to know whether the FIFO is full or empty.
