Buriedcode
Full Member level 6
- Joined
- May 6, 2004
- Messages
- 357
- Helped
- 43
- Reputation
- 86
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- London
- Activity points
- 8,887
Hi, I've got 2 64 MC CPLD's, and I would like to be able to create designs for 128 macrocell devices. Assuming I can easily partition a design to fit on two chips, is there any special way I should 'physically'(or electrically) connect them? I mean, is it OK to simply connect, say, 8 I/O's from one to the other, assuming actual Inputs and Outputs are configured correctly? You see I'm designing a dev. board for these CPLD's and I don't want to order the PCB only to find out that I require a buffer or something. So, basically, is it ok to directly connect an I/O from one chip the I/O of another? Both chips being identical (MACH4A5-64/32)
It seems like a silly question, because Microcontrollers don't mind it, but I've had a couple of CPLD's that heated up quite badly when I connected them together.
Thanks
Buried(in)Code
Thanks
Buried(in)Code
