FreshmanNewbie
Advanced Member level 1
I have a couple of questions regarding the Basics of ESD.
Usually, when we employ ESD protection, say placing a TVS diode on the signal line, the other end of the ESD diode terminal:
a) Will be connected to the ground if the signal is a single-ended signal.
b) If the signal is a differential signal, should the other end of the diode should be connected to the other signal pair of the differential signal or should the other end of the diode has to be connected to ground? What happens if connected to other signal pair or ground?
Can someone clarify this point?
Also, is there a concept of differential mode ESD protection and common mode ESD protection (similar to common mode and differential mode noise?)?
My basic understanding question is that when an ESD hits our PCB through a connector pin, should the ESD energy be dissipated through our board ground or is it better if the ESD energy is made return back to its source? Can it be returned back to its source?
