John Xu
Member level 3
I have two questions on the rsistor variation for simulation.
First question:
If in my circuit, I used two resistors, the resistors are same type, e.g., all are nwell resistor. Then in full case simulations, can I assume they vary in the same trend? i.e., if one is maximum, another is maximum. It will not happen that one is min, another is max? Is it because that they have the same mask?
Second question:
If I use two different type resistors, e.g.,one is nwell resistor, another is P+ resistor,Then in full case simulations, need I combine them with different independent corners, i.e., one min, another is max, or one is max, another is min?It means we need more simulations to find the worst condition.
Can anyone pls. help on this?
Thanks in advance
First question:
Second question:
Thanks in advance
