babinton
Member level 4
Hi everyone,
I have build simple square wave inverter using off the shelf transformer, now I am interested in moving to more proffessional design area. However, I have to gain some valuabel knowledge first which I know I can get from you people.
First. The design of a high frequency transformer.
I have a transformer I removed from the power pack of a Computer system and I would like to use it for designing a high frequency transformer which I can use in the DC-DC converter stage of my inverter cct. What I want to know is : is the transformer suitable for what I have in mind? if so, how do I go about rewinding it i.e. what will be the primary winding area, current rating, no of turns and also the same question goes for the secondary side for an application using 12V DC input and the converted DC output is 48 V DC for a power rating of 400W( also, if I want to scale the power upward to 1500w, how do I go about doing it).
Second Question
I have a power transformer I removed from a 1000VA regulator. Can I use this transformer for 1500w inverter. How do I calculate the winding parameters for the winding( such as wire guage, current ratings, wire area, current density, winding ratio) for both the primary and the secondary. Also, I want an extra 12V winding on the transformer so that I can charge the supply battery when there is main supply. How do I go about the desing.
The transformer dimensions are
length = 110mm
widht = 95.7mm
and thickness of pile = 50.6mm
finally,
I want to build a filter to filter the pwm output , however I don't know how to select the inductor core and winding to use.( I would appreciate if a book on practical tranformer design can be upload.) I have an inductor I also removed from the same power pack. It is a toroidal inductor with diameter of about 4cm. Can I use this to filter the ouput of a 1500w transformer.
Note: I have already gone through all the post on inverter in this forum, but I still need more help that is why I am sending this post.
I will greatly appreciate your help.
Please. If you have any material on the questions I asked above, I will be glad to receive a mail with the materials attached(my email is : faruq.bello@yahoo.com or ruksy02@yahoo.com).
Thanks
Second Question
length = 110mm
widht = 95.7mm
finally,
Thanks
