I'm sorry to tell u that the first solution u presented can not work because the default value of signal abc will be ignored by the compiler of QuartusII,and the actual requirements will not be met through the second solution.
In fact,I wanna initialize an array in my digital design.THe specific statements are as follows:
type configdatatype is array(0 to 31) of std_logic_vector(15 downto 0);
signal configdata:configdatatype:=(0=>x"0b0a",1=>x"0d0c",2=>x"0f0e",others=>"0000000000000000");
The default value of array configdata are mentioned above,and signal configdata will be variedaccording to the input signals' transition.How can I do to make it happen?
Tremendous thanks,
Dairui
