dingjingfeng
Full Member level 3
linear PA which usually have two amplifying stages.
1. Should each of the stage have a stability factor K larger than unity? Or the K of the whole PA?
2. Should the K larger than unit in the low frequency range(<1MHz)?
3. How to simulation a large signal s parameter to find out the LSSP stability,
is there an example in ADS?
3ks
3ks
