DjinnG
Newbie level 5
I have built the simplest possible linear power supply using the LM338 IC.
Since I was stepping 28V down to 16V the power dissipation was a problem.
I found what seemed to be an elegant (& simple!) solution in the following document: https://www.linear.com/pc/downloadDocument.do?navId=H0,C3,P1243,D4099 - figure 5. It is a freely oscillating switching circuit that is supposed to keep the voltage over the LM338 at a minimal level to lower power dissipation.
In my newbieness, I choped off half the components (the 10K, 2.2K resistors, protection diode & coil), replaced the 2N6667 with an IRFZ44N MOSFET, and used the opamp differently. This got the MOSFET hot enough to start smoking. It never occured to me that the FET was in danger since a quick glance at its datasheet showed that Ids Max is 49A, and my load should draw only 3-4A.
My questions are:
1. It seems the FET is still OK. How can I test it to make sure it is not damaged?
2. Has anyone tried somthing similar? How can the power dissipation be calculated for the FET (so I can properly heat sink it)?
3. Assuming the FET is on, according to its datasheet, it should not get hot by a 3A load current (rDS(on)=0.022). Does the switching cause it to heat up? Connecting it serially - in an on state - with a 3A current still made it heat up. Could it mean it was damaged previously and now has a much higher rDS(on)?
4. From the IRFZ44N's datasheet I learned that Max Vgs=20V, though Vgs=10V will completely saturate it (assuming Vds is high enough). Is that correct?
Thanks for you help.
My questions are:
