Questions about functions and working with I2S
user100
I2S
Can any one clarify my doubt...
1. Is there any start and stop conditions, ack signals in I2S like I2C?
2. will I2S bus will carry address ? or data alone by fixed address for slaves?is ther any single master to multi slave communications?
3. if data is transmitted from the master transmitter fifo how can use (SW)word select signal, when should it go high or low ?
4.if transmitter is the master data line SD will be unidirectional?
Thanks in advance
Re: I2S
Check this link
Re: I2S
Thanks for u r replay but this links gives entairly about I2C, this dosnot have answer for my Questions
Re: I2S
let's try to read below doc. it might be useful for you understanding I2S bus.
