matrixofdynamism
Advanced Member level 2
An LED has forward voltage, backward voltage and forward current. These matter in a circuit. So I have the following questions:
1. If an LED has forward voltage of 3.3V, what will happen if it is connected to a device that can only go upto 1.8V at its output? Will it not hardly light at all since a diode curve is quite flat until the forward voltage is reached?
2. If an LED has forward voltage of 3.3V and it is connected to output of a device that outputs 3.2-3.4V, is there a need to put a resistor to limit the current flow? if not then why not and how much current can be expected to flow through the LED in such a case without a resistor to limit it?
3. Looking at the diode curve that suddenly shoots up, I am quite sure that a resistor should be added and the built in current limit (of a few 10s of mA) of the driver's output buffer should not only be relied upon. However, if the LED is rated 3.3V forward voltage and I connect a resistor in series with it, I am not sure how much voltage will drop across the resistor and how much current will pass through it.
4. Will the LED light up if more than reverse voltage is applied but a resistor is used to limit the current flow? Will the LED die in such a case over time?
