I have a bus with 32 bits. The 24 MSB bits connect to gnd, and the 8 LSB bit connect to a<7:0>. We can give a wire name as gnd,gnd,...,gnd,a<7:0>. There are totally 24 gnds in the wire name. But this way is very tedious.
In verilog, there is a way like this: 24{gnd},a<7:0> .
Is there a simple way to name the wire in Cadence?
I have a behaviour model of bin2dec with 32bit input, only the 8LSB connects to the output of another block, the 24MSB should be connected to gnd. That's it.
BTW, <*24>gnd,a<7:0> works, but gnd*24,a<7:0> doesn't.
