cjupiter
Member level 2
I just wanted to know if i can use the channel length modulation coefficient for a bsim3v3 transistor (pclm) when calculating the output resistance of the transistor. Since ro is approx 1/lambda x Id. Can i use the pclm value here instead of lambda. The reason i ask is because lambda for level 1,2 etc models is usually around 0.01, whereas pclm values are sometimes greater than one.
Ta
Ta
