First question:
10u/6V3 means you should find a 10 micro farad capacitor with maximum voltage of 6.3V. If you can't find it, use 10u/10V, or 16V instead.
Second question:
Pin number 14 of the 74HC125D should be connected to VCC and pin number 7 should be connected to ground.
Thank you !!! rikie_rizza
I am a Chinese boy loving electronic.
This is the first time i ask here.
Thank you for your apply!
I want to make friend with you.OK???
My English is not good. I want to learn with you.
Last Thanks.
My email : zhaoshuo_111@163.com
