Questions about 2N3904 BJT maximum Vbe and Ib
eem2am
Banned
BJT max Vbe and Ib
Hello,
Regarding inrush into offline SMPS DC Bus caps………
I have an inrush limiter whereby a FET (M2) is switched on from a 12V power supply , in order to short out the inrush limiting resistor (R22) , after the inrush event at switch-on has taken place.
-the point is that the 2N3904 BJT Q4 gets a base current of 43mA peak during the inrush event.
-is this too much for it?
-the datasheet says nothing of maximum Ib.
also, during the inrush event, the BJT Q4 suffers a Vbe of 1.6V peak.
--is this too high a Vbe for a BJT like 2N3904, -the datasheet says nothing.
here is the schematic:
https://i53.tinypic.com/s14wv8.jpg
…by the way, , Q4 prevents M2 from spuriously turning on when the voltage across R22 suddenly rises.
Re: BJT max Vbe and Ib
For reliability, I would limit the base current to less than 10...20mA. I think 43mA is a bit on the high side.
--is this too high a Vbe for a BJT like 2N3904, -the datasheet says nothinug.
If that's a forward voltage then it's too high. The reverse voltage can be 6 volts according to the datasheet (https://www.fairchildsemi.com/ds/2N/2N3904.pdf).
I wasn't able to view this for some reason (401 Authorization Required).
though given that this high Ibe and high Vbe only last for around 10ms do you still think it's excessive?
I don't want to add more speculations about unspecified maximum ratings.
But I don't see an actual need for Q4 and the ensemble of parts around it. A simple capacitor in parallel
to R23 would do the same ("prevents M2 from spuriously turning").
