FreshmanNewbie
Advanced Member level 1
I'm using this Battery Charger IC - MCP73831.
So, I am using a SOT-23 package.
My input is 5V, the output Vbat charge regulated voltage on the Vbat pin is 4.2V and the maximum charge current is 340mA.
So, by calculation of power dissipation as per section 6.1.1.3 on page 18, it says that, for my condition,
Power Dissipation = (5V - 2.7V) * 0.34A = 782mW
Maximum junction temperature = (0.782 * 230degC/W) + 25deC (ambient) = 204degC approx.
But on page 3, absolute maximum ratings for maximum junction temperature are given as "Internally limited".
My questions:
So, the device will always be stuck in this cycle and will never fail due to excessive junction temperature which is why they mentioned that the junction temperature will be internally limited, is it?
My questions:
- What does "Internally limited" mean for junction temperature?
- While searching for this answer, I searched for thermal shutdown and found section 4.10 on page 14 which says that the device will go to thermal shutdown if the die temperature exceeds 150degC.
