Question with installation of Cadence IC 5033 on Linux RH7.3
easy4880
Newbie level 5
Newbie level 5
I have read some posts about cadence installation on Linux.
Thank you for these useful posts.
but when I have installed 48%, this error pops up.
" loading icms50.33-p111lnx86 5 image not found
SL-11: Error loading software ...
Refer to /tmp/load.msg2 for loading "
Is there some people meeting this problem? Can any expert give some advice?
Thanks ^_^
It seems that file you are installing has errors.
Maybe your CD media has some problems while being read.
Thank you for your reply.
I have found the problem and solved it.
Added after 5 minutes:
But there's another problem
when I installed the "IC5003 lnx86 ISR 200402060002 CDROM # 1 and 2", another CDROM is required "IC5003 lnx86 P/N 356-70352-0301 CDROM # 1 ".
but there are totally 2 installation disc of cadence ic5003.
dose anyony know what's this THIRD disc?
thanks
Re: Question with installation of Cadence IC 5033 on Linux R
thanks
Your CD set is the hotfix CDs, you need to have another set, it's the base CDs set
thanks
What this hotfix mean? My installation set is not a full-function set?
and where can i find the base CDs set? how many discs the base CDs set have?
thanks a lot.
Thanks ^_^
Did the error message always appear at fixed time? i.e. the 48%, in this case i think that you may have corrupted CDs.
Thanks ^_^
thank you for your help, ahmad_abdulghany.
the 1st problem has already been solved. do you know something about the 2nd ont?
thanks a lot.
Hot fix means the update set of software. Your installation medias are not complete. You need another 3 Baseline CDs for IC5033 lnx86.
for your installation, you need six cds, 3 bases and 3 isr (or other type of fix), unless you just want to install base only, in such case, only 3 bases cd arerequied, if you start your installation from isr, then you need all these 6 cds.
