Question Related to the typecasting from bool to char
chandu.kurapati
Full Member level 3
Full Member level 3
Bengaluru, India
Hello,
What happens when we typecast the bool variable to char and vice versa char variable to bool??
Anyone please explain with example.
Thanks & Regards,
CHandu.K
Can't be answered generally. Bool e.g. defaults to 32 bit with some 32-bit compilers. On PIC processors, bool might be a single bit variable type.
Hello Easyrider!
I think for the data size, you're right, although FvM says that some compiler default to 32 bits.
In general, the cast does nothing except giving a hint to the compiler on how to interpret it.
The data itself does not change. For example, if you read a stream of uint8 from the serial port
and want to print if with printf, it simply does nothing, but will tell the comiler to interpriet the
uint8 * stream as char *, and that's it. Not even 1 bit of the stream will change.
Now that's the same for bools. If they default to uint8, then a cast to bool tells the compiler to
interpret it as a bool.
And if you have a bool returning function like bool IsAscii(char c);, then if you have these statements:
uint8 a;
a = IsAscii('a');
then some compiler will start yelling because you assign a bool to a variable which is uint8, (although
it's the same). And some other compiler will not even issue a warning.
Dora.
The "vice versa" means lose of information, any value different from Zero would yield true, therefore it is not exactly a typecasting opperation but rather a logical evaluation (the inverse opperation would not give the original value).
