sda
Member level 5
A question regarding TV channel synthesis.
We take for instance a PLL TV Tuner using the TSA50XX series of chips.
Most, if not all, have a 4 Mhz clock.
The divisor is 512 (taken from the datasheet) which produces a 7.8125 Khz (4.000.000/512) reference.
The prescaler used (again taken from the datasheet) is 8.
Step size is : 7.8125 * 8 = 62.5KHz.
So, If we want the tuner to tune to Ch 21 for instance, the LO frequency must be :
471.250MHz (F-in)+ 38.9MHz (IF Offset) = 510.150 MHz.
To calculate N, it's 510150000/62500, which gives us 8162.4 which isn't possible.
The closest value for LO would be 510.125MHz (8162 programable divider)
This gives us a 25KHz tuning error.
Can someone confirm the above, or am I missing something?
Cheers
sda
Cheers
sda
