FreshmanNewbie
Advanced Member level 1
I'm going through the datasheet of this MOSFET driver IC - MIC5021 to understand the pins and the terms better.
In the first page, it is mentioned as, The MIC5021 high-side MOSFET driver is designed to operate at frequencies up to 100 kHz (5 kHz PWM for 2% to 100% duty cycle)"
I want to understand if this 100kHz is given at the TTL pin of the IC or does it come as the output pin - the GATE pin? If not, what is the input given to the TTL pin? Is it PWM? Also, if the 5kHz PWM is 2% duty, then 100% duty would be 250kHz right? But it is mentioned as the drive is designed to operate at frequencies upto only 100kHz? How to understand this?
