FreshmanNewbie
Advanced Member level 1
I see that this Ethernet PHY transceiver has voltage mode, and line drivers. Since it has on-chip termination resistors, I understand that it has voltage mode line driver.
One general question I now have is that,
- With regards to the Ethernet cable, (Cat6a), which type of line driver will result in more emission issues? Whether voltage mode line driver or current mode line driver will cause more emissions?
- Can the edge rates be reduced by changing register values?
