leocyh
Newbie level 3
Hello everyone. I am building an IC circuit which a KDS crystal oscillator (KDS Part Number DSO751SR, 98.304MHz, 50ppm @ -10C to +70C, Input voltage +3.3 V +/- 10%) was used originally. But now I need to use another oscillator instead. You can see the datasheet of this item in the attachment. Or you can find the datasheet at
When I look up the datasheet from KDS, I found that this oscillator has a very small "Supply Current" of 6mA (but it is measured "under NO LOAD" condition). I think it is strange . Most of the datasheet will present this data "under load".
I have an oscillator on hand, which is almost everything same as this KDS oscillator except the Supply Current. My oscillator is having the Supply Current as "45mA MAX under load = 15pF" (KDS oscillator also has the output load as 15pF mentioned in the datasheet. But as mentioned above, its Supply Current is 6mA under "No Load" condition)
I want to know will there be any problem to my IC circuit if I put my oscillator into it? I am very concerned about "Supply Current". Please someone who is expert of it answer my question.
