chang830
Full Member level 5
I have a question on the ESD protection. We have taped out a mixed chip moths ago and the silicon has returned. We are measuring it now. The function is good but the ESD test failed. We are very depressed about it. We have 16 pins and four pins did not pass the 2000V test in human body mode. Pls. see the attached the ESD strategy for our design.
From the diagram, we can see that the ESD discharge path is the analog VDDA/GNDA for all the pins. We take the digital VDDD and GNDD as a normal I/O pin. But concerning the VDDD and GNDD bounce(we have the concern the bounce will reach up to 0.7V and fault trigger the ESD), we only put half diode clamp on them, respectively. So, it is not a really I/O pin.
The ESD test showed that the four pins failed. Three digital output pin which is the CMOS output and one analog pin.Three digital output pin did not pass the negative pulse to GNDA strike. And moreover, two of them did not pass the positvie/negative pulse to IO. The analog pin did not pass the negative pulse ot IO.
We have no idea what happed on our ESD strategy. Would any ESD experts can help me?
Thanks a lot!
Thanks a lot!
