Question on split circuit, on how the impedence/resistance splits with the voltage.
Lahearle
Newbie
Newbie level 1
New to electronics, need to know how the speed of the current is effected by the impedance when the circuit is split/recombined at a certain point (in blue.)
I appreciate English is not your first language, but the question as phrased does not make any sense. I think that what you are looking for is Kirchoff's voltage and current laws. There are plenty of hits that explain it if you search for Kirchoff's current & voltage law.
Sum of currents entering and leaving a point is zero.
Sum of voltages around a loop is zero.
The picutre is not clear either (at least to me).
In electronics we have standardized symbols and technical terminology .. to explain clearly and avoid misunderstandings.
* I see an earth symbol ...
* and I see a couple of yellow lines (which - in schematic - are ideal connections/wires (without impedance)
* and I see the colored circles. Don´t know what they mean.
Impedance is Volts/Amperes --> V/I ..
Impedance (in opposite to resistance) causes phase shift and usually depends on frequency.
For a single frequency:
* If two impedances are in series ... and both impedances have same phase shift --> the impedances add.
* If two impedances are in series ... and both impedances have 180° phase shift with respect to each other --> the impedances subtract.
* If you want to add two impedances that are connected in parallel .. you have to calculate with the according conductivity AND their phase shift.
...and if you have a mixture of frequencies .. it´s becoming even more difficult.
And generally:
* For current to flow ... you need a closed loop (I miss here). Without closed loop --> no current flow --> calculations impossible.
* fequency plays a big role for discussion: Are we talking about the impedance of a lod connected to a 50Hz mains grid? Or are we talking about GHz impedances for antennas and wirless communication? .. or characteristic impedanes of cables?
My recommendation:
Do some research online. Lern basic terminology and basic symbols (nothing fancy). Then tell us in more details what you want to do and what you need to know.
Klaus
LaTeX Commands Quick-Menu:
