Question on Op-Amps- is max output given per package or amp?
hemant03
Junior Member level 1
Question on Op-Amps
I have a question on Op-Amps. Generally we find dual or quad op-amps an a IC. In the specsheet, there is a rating mentioned for the max output current. Does that signify the max output current from the package or per amplifier?
Thanks,
- Hemant
Re: Question on Op-Amps
Hi
In general it is per channel, rather per chip,
check with the graphs provided in the datasheets of that opamp.
--Babesh
Question on Op-Amps
If you post the part number that you are interested in, we can give you a more definite answer.
But, generally, for a max current specified under "Absolute Maximum Ratings" it would apply to the whole chip, and for a current specified under "Electrical Characteristics" it would apply to each opamp.
Don't take that as fact though - it's always best to confirm what your part's datasheet says.
Also note that you don't really want to to a design that regularly runs an IC close to it max ratings. This is usually where your design will eventually fail - especially when the system heats up somewhat.
Generally what I have noted is if a current rating is per amplifier then they mention that in the specsheet e.g LT1638 else it's a package rating.
Thanks,
- Hemant
