Question on low loss substrate?
amanda.
Junior Member level 2
Hi friend,
What is low loss substrate?
I'm seeking this kind of material for antenna design, anybody mind to list down some low loss substrate that available in the market?:wink:
Thank you.
The loss tangent is a metric of the quantity of electrical energy which is converted to heat by a dielectric. Low loss of the material maximizes the antenna efficiency.
Here is a nice chart for losses of different dielectric materials:
Thank you for the comments,
Is the Duroid substrate can be consider as a low loss substrate?
So what is suspended stripline?
Yes, Duroid is a very low loss substrate.
Suspended stripline technology is mainly used in high frequency transmission lines, due to higher Q and lower loss than standard strip or microstrip lines.
Hi vfone,
Thanks for explain.
Is there any advantages of using substrate?
substrate gives you structural integrity. if you want to increase your efficiency you can also have a regular microstrip antenna without the back (ground conductor) but suspend it over a sheet of metal which will act as the ground.
Hi mkonca,
Thanks for explain.
