Question of partial differentiation in polar coordinates
Alan0354
Full Member level 4
Full Member level 4
For Polar coordinates, \[r^2=x^2+y^2\] and \[x=r\cos \theta\], \[y=r\sin\theta\]
\[r^2=x^2+y^2\Rightarrow\; r\frac{\partial {r}}{\partial {x}}=x+y\frac{\partial {y}}{\partial {x}}\]
\[\Rightarrow\; \frac{\partial {r}}{\partial {x}}=\frac{x}{r}+\frac{y}{r}\frac{\partial {y}}{\partial {x}}\]
\[\frac{\partial {y}}{\partial {x}}=0\], then \[\frac{\partial {r}}{\partial {x}}=\frac{x}{r}\]
\[\frac{\partial {r}}{\partial {x}}=\cos\theta\] as \[\frac{\partial {y}}{\partial {x}}=0 \]
You can now put in \[90^o\;>\;\theta\;>45^o\], you'll get \[r>x\] and \[\frac{\partial {r}}{\partial {x}}>1\]
Let's just use an example where ##\theta =60^o##, so to every unit change of \[x\], \[r\]will change for 2 unit. So \[\frac{\partial {r}}{\partial {x}}=2\]
The same reasoning, \[r=2x\]. So using this example, \[\frac{\partial {r}}{\partial {x}}=\cos 60^o=0.5\] which does not agree with the example I gave.
I am missing something, please help.
The above reasoning is wrong.
You can now put in 45.<\[\theta\]<90 , you'll get r>x and \[\partial\]r/\[\partial\]x=x/r
which will be equal to 1/2 for theta of 60 degrees which means that r=2x which implies that x/r=1/2.This implies that \[\partial\]r/\[\partial\]x=x/r=0.5 which is right and satisfies the condition.
The above reasoning is wrong..
Thanks for the reply, but in my example, \[\frac{\partial {r}}{\partial {x}}=2\]
if x=r*cos(theta) ==> r=x/cos(theta) ==> dr/dx=1/cos(theta)
I follow what you are doing, problem is the book and other articles showed exactly how I derived in my first post that \[\frac{\partial{r}}{\partial{x}}=\frac {x}{r}\]. That is really my question. You can see from my first post that \[\frac{\partial{y}}{\partial{x}}=0\]
\[\frac{\partial {y}}{\partial {x}}=\frac{\partial {y}(r,\theta)}{\partial {r}}\frac{\partial {r}}{\partial {x}(r,\theta)}+\frac{\partial {y}(r,\theta)}{\partial {\theta}}\frac{\partial {\theta}}{\partial {x}(r,\theta)}=\cos\theta \frac{\partial {y}(r,\theta)}{\partial {r}}-\frac{\sin\theta}{r}\frac{\partial {y}(r,\theta)}{\partial {\theta} }= 0 \]
Yes, my derivative is wrong. This is due to the fact the x, y and r are related one each other by the equation:
r^2=x^2+y^2
so we cannot derive only one of the two x=r*cos(theta) or y=r*sin(theta) as I did.
We have r=(x^2+y^2)^(1/2) then deriving with respect to x:
dr/dx=2*x/[2*(x^2+y^2)^(1/2)]=x/[(x^2+y^2)^(1/2)], substituting the polar form:
dr/dx=r*cos(theta)/r=cos(theta) that is the same result you have.
r^2=x^2+y^2
Thanks
Now what does that leave me.....or us? You agree with me, but neither one of us agree with the book and some articles!!!
Now I am officially lost!!! I since posted this question in two different math forums, people there both asked and clarified, and then no response just like here!!!
I have one book and at least one article derived the equations like in my first post, but obviously the example I gave does not agree with the first post and I triple checked my example. I don't think I did anything wrong.......apparently I have not get any suggestion otherwise from three forums!!! I am pretty sure I am missing something as the book I used is a text book used in San Jose State and I studied through 7 chapters and yet to find a single mistake until the question here.
Anyone has anything to say?
From my example,
\[\frac{\partial{r}}{\partial{x}}=\frac{r}{x}=\frac{1}{\cos\theta}\]
And this answer makes a lot more sense.
Thanks
Thanks
I think my answer agreed with the articles. dr/dx=cos(theta)
instead dr/dx=1/cos(theta) is wrong, as I said this is due to the fact that you cannot forget that x,y and r are all related one each other.
The same is in your example you just take into accout only one of the equations. Isn't it ?
I think that there must be some printing mistake in the book from what I see.
What on earth are you doing? Assuming "r" is a constant, any derivative of r will be zero.
Ratch
