bluestatic
Junior Member level 3
lvds driver design
I'm doing a LVDS driver design, which basically is a differential amp, the input of this diff amp is a single-end signal A and its inversion NA. (swing from 0V to 3.3V)
NA is generated from A by using an inverter, so there is a delay time (or skew) between them, let's say, 400ps. Here come the problem, from the simulation I can see that this 400ps skew can cause very seriouse spike on output current. And sometimes it cause output common mode changes.
So I'm wondering if anyone knows how to generated a fully complementary pesudo differental pari from one single end input A.
many thanks
many thanks
