DrDolittle
Full Member level 3
- Joined
- Sep 24, 2004
- Messages
- 162
- Helped
- 5
- Reputation
- 10
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- Within arm's reach
- Activity points
- 1,443
Work
Consider a briefcase lying at rest on the ground. When i lift the briefcase to a table at height "h" i do positive work "mgh" and the gravity does negative work eventuating in zero work. This holds with the formula for work,that is, the difference in kinetic energy between 2 states is zero. When i bring the breifcase off the table i do negative work. What direction the gravity should act and why ?
As the net work done is agin zero in the second case the gravity should upwards. How ?
Regards
drdolittle
Regards
drdolittle
