Ipanema
Member level 1
Zener Diode
I'm using a zener diode to set a reference voltage of 1.8V. Attached is the datasheet of the zener diode. My circuit consist of a variable current source (upper) connected to the zener diode (lower).
Questions :
1) Can zener diode works by current biasing instead of voltage biasing.
2) In the datasheet (page 3), MMSZ4678T1 breakdown voltage range is between 1.71V to 1.89V at 50uA Izt. What would be the breakdown voltage range for 0~10mA of current? From Figure 9, it shows that the voltage will range from 1V to 2V. How true is this?
3) Pls suggest any other way of generating 1.8V reference from a variable current source.
Thanks.
Questions :
Thanks.
