neoaspilet11
Full Member level 5
![Full Member level 5](/styles/images/ranks/flevel2.gif)
- Joined
- Sep 29, 2005
- Messages
- 277
- Helped
- 29
- Reputation
- 56
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cebu, Philippines
- Activity points
- 4,048
Hello Everybody!
I encountered some problems with proteus ISIS lite. Please help
1.) I have a subcircuit and a main circuit. Is theground in the subcircuit connected to the gorund of the main circuit? or do i need to place a port for the ground?
2.) I have a bus in the subcircuit and I named it C[0..39]. I also named the port bus terminal of the subcircuit as C[0..39]. I connected a bus from the main circuit to teh subcircuit bus terminal. Should the bus be also named C[0..39]? (I did this already but it is not working). Can I place a diffrent name to this bus (the one connected to teh subcircuit bus terminal)?
3.) If I place a Port termal as in the example above, is the bus inside the subcircuit automatically connected to this port terminal? If not how to connect it?
4.) If I make another copy of the subcircuit, then the bus name will also be copied.
If I connect another bus to the bus terminal of the second subcircuit, should the bus name also be the same as in the first subcircuit?
I tried to use the proteus help but none to avail. If you happen to have some experience with this before please help.
Thanks,
neo
Thanks,
neo
