cjupiter
Member level 2
non-overlapping clocks
I have a SC integrator implemented with complimentary switches. I use non-overlapping clocks. Does it matter if the complimentary clocks overlap.
What i mean is, the complimentary switch runs on two clocks that are the inverse to eachother. ie. Clock and then clockbar. So in an integrator there are two non-overlapping clocks and therefore with comp. switches two more clocks that are inverse to eachother. I cant get those two clocks to not overlap. Is this okay?
I hope i made sense here :?
