question about two NMOS differential pairs and one PMOS differential pairs in my rail to rail input comparator?
ICworker
Newbie
Newbie level 1
hey friends
in my comparator,there are two nmos differential pairs and one pmos differential pairs.I don't how to analysis this structure and what role does this structure play in rail to rial input。In addition, what is the purpose of using two bipolars in the folded cascode structure.
thanks for you help!
They are questions for the grown-ups but to fill in time until they arrive...
I'm not an IC designer, more of an ignoramus. I've seen op amp r2r with p and n pairs, I don't recollect seeing one with two n pairs. The p inputs are not visible in the partial schematic, I think.
BJTs may be used for (biasing and) temperature compensation. Shame emitter resistor values are missing. I assume they are there to balance nmos that with temperature rise turns on more, so bjts turn on more, so nmos (and obviously, cascode voltage rise with temperature rise also controlled this way) is turned off more, for a relative degree of temperature stability?
With so much missing from the incomplete schematic, ... bit of a guessing game.
Possibly, one n pair wasn't enough to modulate and if needed, cut out supply to pmos in cascode stage, so right-hand pair of n inputs finish the job off, or are just there to drain unwanted leakage voltages from next pmos pair in cascode?
But don't listen to me, I am really clueless about this kind of stuff.
