Question about transmission rate size in GSM
husseinadel
Full Member level 3
Full Member level 3
EGYPT,CAIRO
question about gsm
hello
i know that channel transmission rate in gsm is 270 kbps,,and signals after speech coding and channel coding is 22.8 kbps,,,as channel (carrier) has 8 time slots so,,22.8*8 is less than 200 kbps so,,what is the 270 kbps holds? as it is larger than 22.8*8 kbps
thanks
question about gsm
u forget that there are channel coding after the source conding( speech coding)
Re: question about gsm
thanks for replying but if you read my topic well you will find that i said:"signals after speech coding and channel coding is 22.8 kbps"
please read well the topic before posting
regards
I agree with Eng/ waleedelsafoury
